You can configure IPv6 VRRP to preempt the existing router. If a new VRRP router is added to the network with a higher priority than the existing routers, then the new router becomes the master. If preempt-mode is disabled, then the new router does not become a master, it transitions to master only when the current master is down. By default, preempt-mode is enabled.
  1. Enter Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]} or interface vlan <1–4059>
  2. Enter the following command:
    ipv6 vrrp <vrid> preempt-mode enable
  3. Use the following command to set the IPv6 VRRP preempt-mode to its default value:
    default ipv6 vrrp <vrid> preempt-mode
  4. Use the following command to disable the IPv6 VRRP preempt-mode:
    no ipv6 <vrid> preempt-mode enable
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# interface gigabitethernet 1/2
Enabling IPv6 VRRP preempt-mode for interface 1/2
Switch:1(config-if)# ipv6 vrrp 1 preempt-mode enable
Variable definitions
Use the data in the following table to use the ipv6 vrrp <vrid> command.
Variable
Value
enable
Enables preempt-mode for VRRPv3 for IPv6.
vrid <1–255>
Specifies the virtual router ID.
