![Note](images/note.png)
This procedure only applies to the VSP 7400 Series.
Perform this procedure to view the remote I-SID forwarding database (FDB) on the switch.
To view the T-UNI I-SID FDB entries filtered on a port that is part of an MLT, you must mention the MLT ID in the option for the port.
- Select ISID Remote.
- Optional: Select the Filter button to filter the rows on basis of specific criteria.
FDB Field Descriptions
Use data in the following table to use the FDB tab.
Name |
Description |
IsidId |
Specifies the service interface identifier (I-SID). |
Address |
Specifies the MAC address of the port assigned to the specific I-SID or C-MAC learned on the particular I-SID. |
Status |
Specifies the learning status of the associated MAC. |
Port |
Specifies the port on which the MAC is learned for the specific I-SID. |
PortType |
Specifies if the MAC address is learned locally or on an NNI port from a remote destination. |
RemoteMacDestAddr |
Specifies the virtual BMAC address or system-ID of the remote destination. |
RemoteMacBVlanId |
Specifies the B-VLAN ID on which the remote destination was discovered. |
RemoteMacDestSysName |
Specifies the remote destination system name. |
Cvid |
Specifies the customer VLAN ID of the associated Switched UNI port. |
