Use the following procedure to configure Link Aggregation Control Protocol (LACP) on a private VLAN.
  1. Enter Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]} or interface vlan <1–4059>
  2. Enable trunking:
    encapsulation dot1q
  3. Set private VLAN port type:
    private-vlan [isolated|promiscuous|trunk]
Switch:1(config)#interface GigabitEthernet 1/6
Switch:1(config-if)#encapsulation dot1q
Switch:1(config-if)#private-vlan promiscuous
Switch:1(config-if)#exit
Switch:1(config)#interface GigabitEthernet 1/37
