Functionality is combined with other RADIUS attributes and EAPoL configurations to create untagged S-UNIs.
This attribute supports the following combinations:
From the RADIUS attributes, for untagged VLAN 15. The VLAN from S-UNI becomes untagged:
Egress-VLANID = "838860815" (untagged vlan 15)
Fabric-Attach-ISID += "15:23513"
The following example results in the value 0:1015 for creating an untagged S-UNI.
From the RADIUS attributes, for untagged VLAN 15 and RADIUS-assigned VLAN. Creates S-UNI for I-SID (VLAN+autoIsidOffset):
Tunnel-Private-Group-Id = "15"
From the EAP configuration:
eapol auto-isid-offset 1000
eapol auto-isid-offset enable
Consider the following when using this attribute:
