Perform this procedure to delete configuration of a specific logical interface tunnel on Fabric IPsec Gateway Virtual Machine (VM).
Deleting the destination IP address for Fabric Extend (FE) tunnel configured on the logical interface tunnel with ID 3.Switch:1> enable Switch:1# virtual-service figw console Connected to domain figw Escape character is ^Y <cr> FIGW> delete logical-intf-tunnel 3 fe-tunnel-dest-ip
The following table defines parameters for the delete logical-intf-tunnel command.
Variable | Value |
<1-255> | Specifies the unique ID of the logical interface tunnel. |
fe-tunnel-dest-ip | Deletes the destination IP address that you configure on the logical interface tunnel. |
mtu | Resets the Maximum Transmission Unit (MTU) value for the specific logical interface tunnel to the MTU value configured globally. |
egress-shaping-rate | Deletes the egress shaping rate on the logical interface tunnel. |
