You can use the Unicast Reverse Path Forwarding (uRPF) feature to reduce the problems that are caused by the introduction of malformed or forged (spoofed) IP source addresses into a network. When you enable uRPF, the switch performs a check to determine if the source IP address of the packet is verifiable. If the address is not verifiable, the system drops the packet.
uRPF runs in two modes:
  • strict mode
  • loose mode (exist-only mode)
  • You must enable the urpf-mode boot flag. See Enable urpf-mode Boot Flag.
    When you try to configure uRPF on an interface, that is, enable or change the urpf operating mode with the urpf-mode boot flag disabled, a consistency check error message is displayed: Unicast Reverse Path Forwarding configuration is not supported when urpf-mode boot flag is disabled.
  • You must log on to the GigabitEthernet Interface Configuration mode in CLI.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
  2. Set or change the urpf operating mode on a port:
    For IPv4, enter: ip rvs-path-chk mode {strict|exist-only}
    For IPv6, enter: ipv6 rvs-path-chk mode {strict|exist-only}
  3. Verify the configuration on the port:
    For IPv4, enter: show ip interface gigabitethernet
    For IPv6, enter: show ipv6 interface gigabitethernet
Example for IPv4:
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# interface GigabitEthernet 1/10
Check whether the source IP address of the incoming packet exists in the FIB table:
Switch:1(config-if)# ip rvs-path-chk mode strict
Switch:1(config-if)# show ip interface gigabitethernet
                                         Brouter Port Ip
PORT VRF   IP_ADDRESS    NET_MASK      BROADCAST REASM   ADVERTISE DIRECT  RPC     RPCMODE
NUM  NAME                                        MAXSIZE WHEN_DOWN BCAST
1/1  Glob~ 192.0.2.1     255.255.255.0 ones      1500    disable   disable disable exist-only
1/10 spbo~ 198.51.100.1  255.255.255.0 ones      1500    disable   disable disable exist-only
PORT  VRF
NUM   NAME
1/1   GlobalRouter
1/10  spboip
Example for IPv6:
Switch:1> enable
Switch:1(config)# interface GigabitEthernet 4/16
Switch:1(config-if)# ipv6 rvs-path-chk mode strict
Switch:1(config-if)#show ipv6 interface gigabitethernet
                                             Port Ipv6 Interface
IFINDX BROUTER PHYSICAL          ADMIN   OPER  TYPE  MTU  HOP REACHABLE   RETRANSMIT  MCAST    IPSEC    RPC      RPCMODE
INDX           ADDRESS           STATE   STATE            LMT TIME        TIME        STATUS
192    4/16    e4:5d:52:3c:65:02 enable  down  ETHER 1500 2   30000       1000        disable  disable  disable  existonly
                               Port Ipv6 Address
IPV6 ADDRESS                            BROUTER      TYPE    ORIGIN    STATUS
2001:DB8:0:0:0:0:0:ffff/64                   4/16          UNICAST MANUAL    INACCESSIBLE INF      INF
2001:DB8:0:0:e65d:52ff:fe3c:6502/64          4/16          UNICAST LINKLAYER INACCESSIBLE INF      INF
1 out of 5 Total Num of Interface Entries displayed.
2 out of 10 Total Num of Address Entries displayed.
The following table defines parameters for the ip rvs-path-chk mode and ipv6 rvs-path-chk mode commands.
Variable
Value
mode{strict|exist-only}
Specifies the mode for Unicast Reverse Path Forwarding (uRPF). In strict mode, uRPF checks whether the source IP address of the incoming packet exists in the FIB. If the incoming interface is not the best reverse path, the packet check fails and uRPF drops the packet. In exist-only mode, uRPF checks whether the source IP address of the incoming packet exists in the FIB. The packet is dropped only if the source address is not reachable via any interface on that router.
