Configure the date and time to correctly identify when events occur on the system.
![Note](images/note.png)
According to a bill passed by the government of Russia, from October 2014 Moscow has moved from UTC+4 into UTC+3 time zone with no daylight savings. The software includes this change.
- On the Device Physical View, select the Device.
- Click Chassis.
- Click the User Set Time tab.
- Type and select the correct details.
- Click Apply.
User Set Time field descriptions
Use the data in the following table to use the User Set Time tab.
Name |
Description |
Year |
Configures the year (integer 1998–2097). The default is 1998. |
Month |
Configures the month. The default is 1. |
Date |
Configures the day (integer 1–31). The default is 1. |
Hour |
Configures the hour (12am–11pm). The default is 0. |
Minute |
Configures the minute (integer 0–59). The default is 0. |
Second |
Configures the second (integer 0–59). The default is 0. |
Time Zone |
Configures the time zone. |
