Use this procedure to globally enable IP Multicast over Fabric Connect on the Backbone Edge Bridges (BEBs) that directly or indirectly (using Layer 2 switches) connect to IP multicast senders or receivers. By default, IP Multicast over Fabric Connect is disabled. There is no need to enable IP Multicast over Fabric Connect on the Backbone Core Bridges (BCBs).
Important
IP Multicast over Fabric Connect uses I-SIDs that start at 16,000,000 and above. The device displays an error message if the Layer 2 and Layer 3 I-SIDs are within this range and the system does not enable IP Multicast over Fabric Connect.
You must enable IP multicast over Fabric Connect globally on all DvR enabled nodes (Controllers and Leaf nodes) in a DvR domain.
You must configure the required SPBM and IS-IS infrastructure, which includes the creation of SPBM B-VLANs.
You must create the customer VLANs (C-VLANs) and add slots/ports.
- In the navigation pane, expand to determine if any I-SIDs are within the default range reserved for multicast..
 - Select the tab to determine if the I-SIDs are within the default range reserved for multicast.
 - Select the SPBM tab.
 - If you want to enable multicast on an SPBM instance that already exists, in the Mcast column in the table, select enable.
 - If you want to enable multicast on an SPBM instance that does not yet exit, select Insert.
 - In the Mcast box, select enable to enable IP Multicast over Fabric Connect globally.
 - Select Insert.
 - Select Apply.
SPBM Field Descriptions
Use the data in the following table to use the SPBM tab.
 Name  |
 Description  |
 Id  |
 Specifies the SPBM instance ID. Only one SPBM instance is supported.  |
 NodeNickName  |
 Specifies a nickname for the SPBM instance globally. Valid value is 2.5 bytes in the format <x.xx.xx>.  |
 PrimaryVlan  |
 Specifies the primary SPBM B-VLANs to add to the SPBM instance.  |
 Vlans  |
 Specifies the SPBM B-VLANs to add to the SPBM instance.  |
 LsdbTrap  |
 Configures whether to enable or disable a trap when the SPBM LSDB changes. The default is disable.  |
 IpShortcut  |
 Enables or disables SPBM IP shortcut state. The default is disable.  |
 SmltSplitBEB  |
 Specifies whether the switch is the primary or secondary vIST peer. The default is primary.  |
 SmltVirtualBmac  |
 Specifies a virtual MAC address that can be used by both peers.  |
 SmltPeerSysId  |
 Specifies the system ID of the SPBM SMLT for this SPBM instance.  |
 Mcast  |
 Specifies if IP multicast over SPBM is enabled. The default is disabled.  |
 McastFwdCacheTimeout  |
 Specifies the global forward cache timeout in seconds. The default is 210 seconds.  |
 Ipv6Shortcut  |
 Enables or disables SPBM IPv6 shortcut state. The default is disable.  |
 McastSpbPimGwControllerEnable  |
 Enables or disables ISIS PLSB Multicast SPB PIM Gateway controller. Disabled by default.  |
 McastSpbPimGwGatewayEnable  |
 Enables or disables ISIS PLSB Multicast SPB PIM Gateway. Disabled by default.  |
 StpMultiHoming  |
 Enables or disables MSTP-Fabric Connect Multi Homing. The default is disabled (false).  |
                                                   BVlanOrigin Note:
                                                  Exception: not supported on XA1400 Series and VSP 8600 Series.  |
                                                   Shows how the B-VLAN was created. The values can be config for manual configuration using CLI or SNMP, or dynamic through Zero Touch Fabric Configuration and Auto-sense. The default is dynamic.  |
