Multicast group trace tracks the data flow path of the multicast streams.
  1. Enter Privileged EXEC mode:
    enable
  2. Display the multicast group trace for an IGMP snoop-enabled interface:
    show ip igmp snoop-trace [source {A.B.C.D}] [group {A.B.C.D}]
Switch:1# show ip igmp snoop-trace
                           Snoop Trace - GlobalRouter
GROUP              SOURCE             IN     IN         OUT    OUT        TYPE
ADDRESS            ADDRESS            VLAN   PORT       VLAN   PORT
233.252.0.1        192.0.2.6         500    1/1        500    1/5        ACCESS
233.252.0.10       192.0.2.7         500    1/1        500    1/10       ACCESS
The following table defines parameters for the show ip igmp snoop-trace command.
Variable
Value
group {A.B.C.D}
Specifies the group IP address in the format a.b.c.d.
source {A.B.C.D}
Specifies the source IP address in the format a.b.c.d.
