Use this procedure to configure organizational-specific TLVs for Link Layer Discovery Protocol (LLDP) Media Endpoint Devices (MED). LLDP MED TLVs are enabled by default.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
  2. Disable LLDP MED TLVs for transmission:
    no lldp tx-tlv med {extendedPSE | inventory | location | med-capabilities | network-policy}
  3. Restore LLDP MED TLVs for transmission to their default value:
    default lldp tx-tlv med {extendedPSE | inventory | location | med-capabilities | network-policy}
  4. Verify the configuration:
    show lldp tx-tlv med
Switch:1>enable
Switch:1#config
Configuring from terminal or network [terminal]? t
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#interface gigabitethernet 1/2
Switch:1(config-if)#no lldp tx-tlv med inventory
Switch:1(config-if)#no lldp tx-tlv med location
Switch:1#show lldp tx-tlv med
                               LLDP port med tlvs
Port          Med        Network   Location  ExtendedPower Inventory
           Capabilities   Policy                ViaMDI
1/2        disabled      enabled   enabled   enabled      disabled
Switch:1>enable
Switch:1#config
Switch:1(config-if)#default lldp tx-tlv med inventory
Switch:1(config-if)#default lldp tx-tlv med med-capabilities
                               LLDP port med tlvs
1/1        enabled       enabled   enabled   enabled       enabled
1/2        enabled       enabled   enabled   enabled       enabled
The following table defines parameters for the lldp tx-tlv med command.
Variable
Value
extendedPSE
Specifies the extended power-via-MDI Media Endpoint Device (MED) transmission TLV. This TLV is applilcable for POE-capable switches only.
The default is enabled on POE-capable switches only.
inventory
Specifies the system capabilities MED transmission TLV.
The default is enabled.
location
Specifies the system description MED transmission TLV.
med-capabilities
Specifies the system name MED transmission TLV.
network-policy
Specifies the network policy MED transmission TLV.
