Display VLACP statistics for specific ports to manage network performance.
![Note](images/note.png)
Slot and port information can differ depending on hardware platform.
You can enable sequence numbers for each VLACPDU to assist in monitoring performance. The switch counts mismatched PDU sequence numbers to determine packet loss information. By default, sequence numbers are enabled.
You can use the show commands from Privileged EXEC mode but must enter Global Configuration mode to enable or disable the sequence numbers.
Determine if sequence numbers are enabled, and then view port statistics. Port numbering may differ depending on your product and configuration.
Switch:1(config)#show vlacp ================================================================================ Vlacp Global Information ================================================================================ SystemId: 32:11:9f:20:00:00 Vlacp: enable Vlacp Sequence Number: enable Switch:1(config)#show interfaces gigabitEthernet statistics vlacp ================================================================================ Port Stats Vlacp ================================================================================ PORT TX RX SEQNUM NUM VLACPDU VLACPDU MISMATCH -------------------------------------------------------------------------------- 8/1 106058 105554 0 12/11 15 12 0 12/23 0 0 0
Use the data in the following table to use the commands in this procedure.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
