The virtual services running on a Virtual Machine (VM) require a console for configuration and monitoring purposes.
Perform this procedure to access the virtual service console port for the specific VM.
This command also works in Global Configuration mode but does not display if you use the question mark (?) help in that mode.
  1. Enter Privileged EXEC mode:
    enable
  2. Enter the following command to access the virtual service console:
    virtual-service WORD<1-128> console
    Type CTRL+Y to exit the console.
Switch:1>enable
Switch:1#virtual-service tpvm console
The following table defines parameters for the virtual-service command.
Variable
Value
WORD<1-128>
Specifies the virtual service name.
console
Accesses the console for the specific virtual service.
