This section lists EAP configuration considerations.
You must configure at least one EAP RADIUS server and shared secret fields.
You cannot configure EAP on ports that are currently configured for the following:
Shared segments
Change the authentication status to auto for each port that you want to control. The auto setting automatically authenticates the port according to the results of the RADIUS server. The default authentication setting for each port is authorized.
When multiple clients are authenticated on the same port, the priority of the latest incoming client is applied on the port, and this priority is retained until all the clients log out on that port.
