Show UDP forward information to view information about the UDP forwarding characteristics of the device. UDP forwarding only supports 128 entries.
There are four show options:
Show the interface information
Show the port forward information
Show the port forward list information
Show the protocol information
Display the UDP protocol table with the UDP port numbers for each supported or designated protocol:
Switch:1>enable Switch:1#show ip forward-protocol udp ================================================================================ Udp Protocol Tbl - GlobalRouter ================================================================================ UDP_PORT PROTOCOL_NAME -------------------------------------------------------------------------------- 37 Time Service 49 TACACS Service 53 DNS 69 TFTP 137 NetBIOS NameSrv 138 NetBIOS DataSrv
Use the data in the following table to use the show ip forward-protocol udp interface command.
Variable |
Value |
<A.B.C.D> |
Specifies the IP address for the interface in a.b.c.d format. |
vrf WORD<1–16> |
Specifies the name of the VRF. |
vrfids WORD<0–512> |
Specifies the ID of the VRF and is an integer in the range of 0 to 512. |
