Use the data in following table to use the clear energy-saver eee stats command.
Perform this procedure to clear information about Energy Efficient Ethernet (EEE) statistics for all ports on a switch, or for a specific port.
  1. Enter Privileged EXEC mode:
    enable
  2. Clear Energy Efficient Ethernet statistics on all ports or specify a particular port:
    clear energy-saver eee stats [port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}]
Variable
Value
port
Specifies one or more ports.
{slot/port[/sub-port][-slot/port[/sub-port]][,...]}
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.
