Use the following procedure to view a summary of SPBM and IS-IS protocol information.
  1. In the navigation pane, expand Configuration > Fabric.
  2. Select IS-IS.
  3. Select the Protocol Summary tab.
Protocol Summary field descriptions
Use the data in the following table to use the Protocol Summary tab.
Name
Description
Globals ISIS
AdminState
Indicates the global status of IS-IS on the switch.
SystemId
Indicates the IS-IS system ID for the switch. Valid value is a 6–byte value in the format <xxxx.xxxx.xxxx>
HostName
Indicates IS-IS system name. This may be used as the host name for dynamic host name exchange in accordance with RFC 2763.
By default, IS-IS system name uses global system name as it is synchronized with the IS-IS system name until the IS-IS sytem name is manually configured.
Globals SPBM
GlobalEnable
Indicates whether SPBM is enabled or disabled at the global level.
NodeNickName
Indicates the nickname for the SPBM instance globally. Valid value is 2.5 bytes in the format <x.xx.xx>.
PrimaryVlan
Indicates the primary VLAN ID for this SPBM instance.
SmltSplitBEB
Indicates whether the switch is the primary or secondary IST peer.
ISIS Interfaces
Circuit Index
Displays the identifier of this IS-IS circuit, unique within the Intermediate System. This is for SNMP Indexing purposes only and need not have any relation to any protocol value.
IfIndex
Indicates the interface to which this circuit corresponds.
AdminState
Indicates the administrative state of the circuit: on or off.
OperState
Indicates the operational state of the circuit: up or down.
ISIS Adjacency View
Circuit Index
Displays the identifier of this IS-IS circuit, unique within the Intermediate System. This value is for SNMP Indexing purposes only and need not have any relation to any protocol value.
AdjIndex
Displays a unique value identifying the IS adjacency from all other such adjacencies on this circuit. This value is automatically assigned by the system when the adjacency is created
AdjIfIndex
AdjState
Indicates the state of the adjacency:
  • down
  • initializing
  • up
  • failed
AdjNeighSysID
Indicates the system ID of the neighboring Intermediate System.
AdjHostName
Indicates the host name listed in the LSP, or the IS-IS system name. The IS-IS system name uses global system name, if the host name is not configured.
