Perform this procedure to show information about the active RP for all the running multicast groups on the switch.
  1. In the navigation pane, expand the following folders: Configuration > IP.
  2. Click PIM.
  3. Click the Active RP tab.
Active RP field descriptions
Use the data in the following table to use the Active RP tab.
Name
Description
GroupAddress
Shows the IP address of the multicast group.
Address
Shows the IP address of the RP router. This address must be one of the local PIM-SM enabled interfaces.
Priority
Shows the priority of the RP.
