![Note](images/note.png)
This procedure does not apply to VSP 8600 Series and XA1400 Series.
For Zero Touch Deployment and assignments of dedicated I-SIDs for FA capable cameras, Wireless Access Points, FA proxy switches and Open Virtual Switches (OVS), configure a specific I-SID to use instead of the onboarding I-SID when a port is in an Auto-sense Fabric Attach (FA) state and detects an FA client.
Create the I-SID.
Associate the I-SID with either a platform or private VLAN; this association is not required on a DvR Leaf.
You can create only one I-SID of each type.
The FA I-SID can be the same as the voice I-SID because they are used by different Auto-sense port states.
The following table defines parameters for the auto-sense commands related to Fabric Attach (FA) I-SIDs.
Variable |
Value |
i-sid <1-15999999> |
Specifies the service instance identifier (I-SID). |
