The notify filter profile exists.
Configure the profile table to associate a notification filter profile with a particular set of target parameters.
 - Click Notify Table.
 - Click the Notify Filter Profile Table tab.
 - Click Insert.
 - In the TargetParamsName box, type a name for the target parameters.
 - In the NotifyFilterProfileName box, type a name for the notify filter profile.
 - Click Insert.
Notify Filter Profile Table Field Descriptions
Use the data in the following table to use the Notify Filter Profile Table tab.
 Name  |
 Description  |
 TargetParamsName  |
 Specifies the unique identifier associated with this entry.  |
 NotifyFilterProfileName  |
 Specifies the name of the filter profile to use to generate notifications.  |
