Perform this procedure to view PoE Power Sourcing Entity (PSE) information for local LLDP-MED on specific ports.
  1. In the navigation pane, expand Configuration > Serviceability > Diagnostics > 802_1ab.
  2. Click Port MED.
  3. Click the Local PoE PSE tab.
Local PoE PSE Field Descriptions
Name
Description
PortNum
Specifies the port.
PSEPortPowerAvailable
Specifies the value of the power available (in units of 0.1 watts) from the PSE through the specific port.
PSEPortPDPriority
Specifies the Power Device (PD) power priority for the PSE port (see RFC 3621):
  • unknown — priority is not configured or known by the PD
  • critical
  • high
  • low
