View Traceroute Results
View traceroute results to view performance-related data.
![Note](images/note.png)
Troubleshooting using ping and traceroute is not supported on EDM. For more information, see VOSS Release Notes. As an alternative, use CLI.
- From the navigation pane, expand .
- Click Ping/Trace Route.
- Click the Trace Route Control tab.
- Select a traceroute entry.
- Click Trace Route Result.
Trace Route Result Field Descriptions
Use the data in the following table to use the Trace Route Result tab.
Name |
Description |
OwnerIndex |
Specifies the index of the owner. |
TestName |
Specifies the name of the test. |
OperStatus |
Specifies the operational status of the test. The default is disabled. |
CurHopCount |
Specifies the current count of hops. |
CurProbeCount |
Specifies the current count of probes. |
IpTgtAddressType |
Specifies the IP target address type |
IpTgtAddr |
Specifies the IP target address. |
TestAttempts |
Specifies the number of test attempts. |
TestSuccesses |
Specifies the number of successful test attempts. |
LastGoodPath |
Specifies the date and time when the last response is received for a probe. |
