![Note](images/note.png)
This procedure only applies to VSP 4900 Series and VSP 7400 Series.
Perform this procedure to configure the VLAN feature on an Extreme Integrated Application Hosting (IAH) port.
VLAN Field Descriptions
Use data in the following table to use the VLAN tab.
Name |
Description |
PerformTagging |
Enables tagging (trunking) on the Extreme Integrated Application Hosting (IAH) port. It can belong to multiple port-based VLANs and a VLAN tag is inserted in every frame it transmits. If it is not checked, the IAH port is an untagged (Access) IAH port. The default value is different for each IAH port. |
VlanIdList |
Shows the VLAN ID to which the IAH port is assigned to. |
DiscardTaggedFrames |
Enables the functionality to discard tagged frames received on the IAH port by the forwarding process, for untagged (access) IAH port. The default is disabled. |
DiscardUntaggedFrames |
Enables the functionality to discard untagged frames received on the IAH port by the forwarding process, for tagged (trunk) IAH port. The default is disabled. |
UntagDefaultVLAN |
Enables the functinality to untag the frames forwarded to the default VLAN, even if the IAH port is tagged (trunk port). The default is disabled. |
UntaggedVlanIds |
Shows the untagged VLAN IDs associated with the IAH port. |
DefaultVlanId |
Specifies the VLAN ID assigned to untagged frames received on the IAH port that match no policy-based VLAN to which the EIAH port belongs. |
SpoofDetect |
Enables spoof detection on the specified IAH port. |
PrivateVlanPortType |
Specifies the following:
