Use this procedure to monitor the IP multicast route statistics at regular intervals.
  1. Enter Privileged EXEC mode:
    enable
  2. Monitor the IP multicast route statistics:
    monitor ip mroute stats WORD<7-160> {A.B.C.D[,E.F.G.H][,...]} [vrf WORD<1-32>] [vrfid <0-255>]
    You can monitor a maximum of 10 group IP addresses.
Monitor the IP multicast route statistics for the group IP address 225.0.0.1. In this example, the statistics are monitored at intervals of 5 seconds for a duration of 300 seconds. The output from monitoring three consecutive intervals is displayed below.
Switch:1>en
Switch:1#monitor ip mroute stats 225.0.0.1
                         MULTICAST STATISTIC
Monitor Interval: 5sec | Monitor Duration: 300sec       Mon Dec 21 16:12:07 2015
                         Multicast Stats - GlobalRouter
GroupAddress     SourceCounter      IngressPackets       IngressBytes    AverageSize
225.0.0.1        1                  4716624              603727872       128
                         MULTICAST STATISTIC
Monitor Interval: 5sec | Monitor Duration: 300sec       Mon Dec 21 16:12:13 2015
225.0.0.1        1                  4767325              610217600       128
                         MULTICAST STATISTIC
Monitor Interval: 5sec | Monitor Duration: 300sec       Mon Dec 21 16:12:19 2015
Monitor the IP multicast route statistics for a maximum of 10 group IP addresses. The statistics are monitored at intervals of 5 seconds for a duration of 300 seconds. The output from monitoring three consecutive intervals is displayed below.
Switch:1#monitor ip mroute stats 225.0.0.1,225.0.0.2,225.0.0.3,225.0.0.4,225.0.0.5,225.0.0.6,225.0.0.7,225.0.0.8,225.0.0.9,225.0.0.10
                         MULTICAST STATISTIC
Monitor Interval: 5sec | Monitor Duration: 300sec       Mon Dec 21 16:22:07 2015
225.0.0.1        1                  9532039              1220100992    128
225.0.0.2        1                  9532041              1220101120    127
225.0.0.3        1                  9532042              1220101248    127
225.0.0.4        1                  9532043              1220101376    127
225.0.0.5        1                  9532044              1220101632    128
225.0.0.6        1                  9532045              1220101760    128
225.0.0.7        1                  9532046              1220101888    128
225.0.0.8        1                  9532047              1220101888    127
225.0.0.9        1                  9532048              1220102016    127
225.0.0.10       1                  9532048              1220102144    128
                         MULTICAST STATISTIC
Monitor Interval: 5sec | Monitor Duration: 300sec       Mon Dec 21 16:22:13 2015
225.0.0.1        1                  9582672              1226582016    128
225.0.0.2        1                  9582674              1226582144    127
225.0.0.3        1                  9582675              1226582272    127
225.0.0.4        1                  9582676              1226582400    127
225.0.0.5        1                  9582677              1226582656    128
225.0.0.6        1                  9582678              1226582784    128
225.0.0.7        1                  9582679              1226582912    128
225.0.0.8        1                  9582681              1226583040    127
225.0.0.9        1                  9582681              1226583040    127
225.0.0.10       1                  9582681              1226583168    128
                         MULTICAST STATISTIC
Monitor Interval: 5sec | Monitor Duration: 300sec       Mon Dec 21 16:22:19 2015
225.0.0.1        1                  9625009              1232001152    128
225.0.0.2        1                  9625011              1232001280    127
225.0.0.3        1                  9625012              1232001408    127
225.0.0.4        1                  9625013              1232001536    127
225.0.0.5        1                  9625014              1232001792    128
225.0.0.6        1                  9625015              1232001920    128
225.0.0.7        1                  9625016              1232002048    128
225.0.0.8        1                  9625018              1232002176    127
225.0.0.9        1                  9625019              1232002304    127
225.0.0.10       1                  9625018              1232002304    128
Switch:1#
Variable definitions
The following table defines parameters for the monitor ip mroute stats command.
Variable
Definition
vrf WORD<1-32>
Specifies a VRF name.
vrfid <0-255>
Specifies a VRF ID.
Specifies the multicast group IP address for which to monitor statistics.
The group IP address is in one of the following formats: a single IP address or a series of IP addresses, up to a maximum of 10.
