    enable
    configure terminal
  2. Generate a new RSA host key:
    ssh rsa-host-key [<1024–2048>]
The following table defines parameters for the ssh rsa-host-key command.
Variable Value
<1024–2048>
Specify an optional key size from 1024 to 2048. The default is 2048.
