View your configuration to review the information and ensure it is correct.
  1. Enter Privileged EXEC mode:
    enable
  2. View ACL information:
    show filter acl <acl-id>
  3. View IPv6 ACL information:
    show filter acl ipv6 <acl-id> <ace-id>
  4. View the running configuration for an ACL and corresponding ACE:
    show filter acl config <acl-id> <ace-id>
Use the data in the following table to use the show filter acl and show filter acl config commands.
Variable
Value
<ace-id>
Specifies the ACE ID. Different hardware platforms support different ACE ID ranges. Use the CLI Help to see the available range for the switch.
<acl-id>
Specifies the ACL ID. Use the CLI Help to see the available range for the switch.
