Perform this procedure to configure the additional addresses for which the virtual router acts as a back up.
  • Assign an IPv6 address to the interface.
  • Enable routing globally.
  • Do not configure RSMLT on the VLAN.
  • Change the VRF instance as required to configure additional addresses on the VRRP interface on a specific VRF instance. Not all parameters are configurable on non-default VRFs.
  1. In the navigation tree, expand the following folders: Configuration > IPv6.
  2. Click VRRP.
  3. Click the Interface tab.
  4. Select an interface.
  5. Click AssociatedIPAddr.
  6. Click Insert.
  7. Type the address.
  8. Type the prefix length.
  9. Click Insert.
Address List field descriptions
Use the data in the following table to use the Address List tab.
Name
Description
IpAddr
Specifies an IP address that is associated with a virtual router. The number of rows on this tab equals the number of IP addresses associated (backed up) by the virtual router
IpAddrPrefixLength
Specifies the length of the prefix in bits.
