Use the following procedure to view the Application Telemetry status counters. The switch assigns an ID to each counter and displays information about each filter rule by name. The information includes how many packets were transmitted to the Analytics Engine that matched the specified pattern in the rule and the total number of bytes in the packets.
  1. In the navigation pane, expand the Configuration > Serviceability folders.
  2. Click Application Telemetry.
  3. Click the Counter tab.
Counter field descriptions
Use the data in the following table to use the Counter tab.
Name
Description
CounterId
Shows the Application Telemetry rule ID.
CounterName
Shows the rule name.
CounterPkts
Shows the number of packets transmitted to the Analytics Engine that matched the specified pattern in the rule.
CounterBytes
Shows the total number of bytes in the packets.
