Displaying foreign sources
Use the following procedure to display the Gateway foreign source database. Foreign sources are originally learned from MSDP or statically configured on the Controller.
  1. In the navigation pane, expand Configuration > IP.
  2. Click SPB-PIM-GW.
  3. Click the Gateway-Foreign-Source tab.
Gateway-Foreign-Source field descriptions
Use the data in the following table to use the Gateway-Foreign-Source tab.
Name
Description
SourceAddress
Displays the foreign source IP address.
GroupAddress
Displays the multicast group IP address associated with the foreign source.
ControllerSysId
Displays the system ID of the controller node that sends this foreign source.
ControllerHostName
Displays the host name of the controller node that sends this foreign source.
GatewaySysId
Displays the system ID of the node selected as the gateway for this foreign source.
GatewayHostName
Displays the host name of the node selected as the gateway for this foreign source.
InVid
Displays the VLAN ID of the SPB-PIM Gateway interface through which the source of this source is reachable.
InPort
Displays the physical interface through which the source of this source is reachable.
OwnerType
Displays if the owner is MSDP or static.
