Use the following procedure to display the IS-IS interface parameters.
  1. Enter Privileged EXEC mode:
    enable
  2. Display IS-IS interface configuration and status parameters (including adjacencies):
    show isis interface [l1|l2|l12] [home|remote]
  3. Display IS-IS interface authentication configuration:
    show isis int-auth [home|remote]
  4. Display IS-IS interface timers:
    show isis int-timers [home|remote]
  5. Display IS-IS circuit level parameters:
    show isis int-ckt-level [home|remote]
Switch:1# show isis interface
                                ISIS Interfaces
IFIDX    TYPE   LEVEL    OP-STATE    ADM-STATE  ADJ  UP-ADJ  SPBM-L1    OP-SPBM-   ORIGIN   AREA   AREA-NAME
                                                             -METRIC    L1-METRIC
Mlt2     pt-pt  Level 1    UP         UP         1    1       10     (A) 10        CONFIG   HOME  area-9.00.02
Port1/21 pt-pt  Level 1    UP         UP         1    1       10     (A) 10        CONFIG   HOME  area-9.00.02
Home: 2 out of 2 Total Num of ISIS Interfaces
Legend:
(A): l1 metric is automatically updated based on detected interface speed.
Switch:1# show isis int-auth home
                              ISIS Interface Auth
IFIDX        AUTH-TYPE   AUTH-KEYID  AUTH-KEY   ORIGIN    AREA   AREA-NAME
Mlt2         none        0                      CONFIG    HOME   area-9.00.02
Port1/21     none        0                      CONFIG    HOME   area-9.00.02
Switch:1# show isis int-timers home
                             ISIS Interface Timers
IFIDX        LEVEL      HELLO         HELLO         HELLO   AREA   AREA-NAME
                        INTERVAL      MULTIPLIER    DR
Mlt2         Level 1        9          3             3     HOME    area-9.00.02
Port1/21     Level 1        9          3             3     HOME    area-9.00.02
Switch:1# show isis int-ckt-level home
                         ISIS Circuit level parameters
IFIDX           LEVEL          DIS        CKTID      AREA   AREA-NAME
Mlt2            Level 1                    1         HOME    area-9.00.02
Port1/21        Level 1                    2         HOME    area-9.00.02
The following table defines parameters for the show isis interface command.
Variable
Value
home
Displays the IS-IS interface information that the system configures in the home area.
l1
Displays the interface information for Level 1.
l2
Displays the interface information for Level 2.
l12
Displays the interface information for Level 1 and Level 2.
remote
Displays the IS-IS interface information that the system configures in the remote area.
The following table defines parameters for the show isis ini-auth command.
Variable
Value
home
Displays the IS-IS interface authentication information that the system configures in the home area.
remote
Displays the IS-IS interface authentication information that the system configures in the remote area.
The following table defines parameters for the show isis ini-timer command.
Variable
Value
home
Displays the IS-IS interface timer information that the system configures in the home area.
remote
Displays the IS-IS interface timer information that the system configures in the remote area.
The following table defines parameters for the show isis ini-ckt-level command.
Variable
Value
home
Displays the IS-IS interface circuit level parameters that the system configures in the home area.
remote
Displays the IS-IS interface circuit level parameters that the system configures in the remote area.
