View the destination cache to see next-hop addresses for destinations.
The destination cache is only populated or updated when IPv6 packets originate locally on the central processor of the switch.
The main purpose of the destination cache is to store, on a per-destination basis, the dynamic Path MTU value currently used when transmitting packets from the local system to the remote destination.
The system uses the PMTU value to calculate how many bytes can fit into an individual packet before fragmentation should be applied.
The command output shows the following information:
the IPv6 destination address
the IPv6 address for the next hop to the destination
the path maximum transmission unit (MTU) for the destination
the time, in seconds, since an ICMPv6 packet-too-big message was received
Not all parameters are available in non-default VRFs.
Switch:1(config-if)#show ipv6 dcache ========================================================================================== IPv6 Destination Cache Information - GlobalRouter ========================================================================================== Destination Address NEXT HOP VID/BID/TID IF_TYPE IF_DATA PMTU PMTU_AGE ------------------------------------------------------------------------------------------ ff02:0:0:0:0:0:0:1 0:0:0:0:0:0:0:0 V-22 real - 1500 0 ------------------------------------------------------------------------------------------ 1 out of 1 Total Num of Destinaton Cache Entries displayed.
Use the data in the following table to use the show ipv6 dcache and clear ipv6 dcache commands.
Variable |
Value |
<1-4059> |
{slot/port[/sub-port]} |
Identifies a single slot and port. If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
vrf WORD<1–16> |
Specifies the VRF name. |
vrfids WORD<0–512> |
Specifies the VRF ID. |
