Configure ACE IPv6 next header entries to have the filter look for specific next headers.
  • The ACL exists.
  • The ACE exists.
  1. In the navigation tree, expand the following folders: Configuration > Security > Data Path.
  2. Click Advanced Filters (ACE/ACLs).
  3. Click the ACL tab.
  4. Select the appropriate ACL.
  5. Click ACE.
  6. Select the appropriate ACE.
  7. Click IPv6.
  8. Click the Next Hdr tab.
  9. Click Insert.
  10. In the Oper field, select the operation type.
  11. In the NextHdr field, select the next header type.
  12. Click Insert.
Next Header field descriptions
Use the data in the following table to use the Next Hdr tab.
Name
Description
AclId
Specifies the ACL ID.
AceId
Specifies the ACE ID.
Oper
The eq parameter specifies an operator for an “equal to” field match condition.
NextHdr
Specifies the next header of the IPv6 header. Specifies hop-by-hop, tcp, udp, routing, fragment, ipsecESP, ipsecAH, icmpv6, noNxtHdr, or undefined.
