View IPv6 VRRP Statistics
View IPv6 VRRP statistics to monitor network performance.
  1. In the navigation pane, expand Configuration > IPv6.
  2. Select VRRP.
  3. Select the Stats tab.
Stats Field Descriptions
Use the data in the following table to use the Stats tab.
Name
Description
InetAddrType
Shows the type of IP address (IPv4 or IPv6).
ChecksumErrors
Shows the number of VRRP packets received with an invalid VRRP checksum value.
VersionErrors
Shows the number of VRRP packets received with an unknown or unsupported version number.
VrIdErrors
Shows the number of VRRP packets received with an invalid VrID for this virtual router.
