![Note](images/note.png)
This procedure only applies to VSP 4450 Series.
View port bridging errors statistics to manage network performance.
- In the Device Physical View, select a port.
- In the navigation pane, expand: .
- Select Port.
- Select the Bridging tab.
Bridging Field Descriptions
The following table describes parameters on the Bridging tab.
Name |
Description |
InUnicastFrames |
The number of incoming unicast frames bridged. |
InMulticastFrames |
The number of incoming multicast frames bridged. |
InBroadcastFrames |
The number of incoming broadcast frames bridged. |
InDiscards |
The number of frames discarded by the bridging entity. |
OutFrames |
The number of outgoing frames bridged. |
