Use the following procedure to link the security association to an IPsec policy.
You cannot delete or modify a security association if the security association links to a policy. To modify a parameter in the security association, or to delete the security association, you must first unlink the security association from the policy. You can only unlink a security association from a policy if the policy does not link to an interface. If a policy links to an interface, you must first unlink the policy from the interface, and then unlink the policy from the security association.
  • The IPsec security association and IPsec policy must exist.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Click IPSec.
  3. Click the Policy SA Link tab.
  4. Click Insert.
  5. In the PolicyName field, type the IPsec policy name.
  6. In the SAName field, type the security association name.
  7. Click Insert.
Policy SA Link field descriptions
Use the data in the following table to use the Policy SA Link tab.
Name
Description
PolicyName
Specifies the name of the IPsec policy.
SAName
Specifies the name of the security association.
