Clear ACL Statistics
Clear default ACL statistics if you no longer require previous statistics.
![Note](images/note.png)
The ACL statistics do not support security action on some hardware platforms.
Use the information in the following table to use the clear filter acl statistics command.
Variable |
Value |
<acl-id> |
Specifies the ACL ID. Use the CLI Help to see the available range for the switch. |
<ace-id> |
Specifies the ACE ID. Different hardware platforms support different ACE ID ranges. Use the CLI Help to see the available range for the switch. |
