Enable RSMLT Edge support to store the RSMLT peer MAC and IP address-pair in the local configuration file and restore the configuration if the peer does not restore after a simultaneous restart of both RSMLT peer systems.
The default is disabled.
RSMLT Edge support configuration applies to both IPv4 and IPv6.
  1. In the navigation pane, expand the following folders: Configuration > IP.
  2. Click RSMLT.
  3. Click the Globals tab.
  4. Select EdgeSupportEnable.
  5. Click Apply.
