Perform this procedure to view PoE Power Sourcing Entity (PSE) information for remote LLDP-MED on specific ports.
  1. In the navigation pane, expand Configuration > Serviceability > Diagnostics > 802_1ab.
  2. Click Port MED.
  3. Click the Neighbor PoE PSE tab.
Neighbor PoE PSE Field Descriptions
Name
Description
TimeMark
Specifies the time filter. For more information about TimeFilter, see the TimeFilter textual convention in IETF RFC 2021.
LocalPortNum
Specifies the port on which the remote LLDP-MED information is received.
Index
Specifies the particular connection instance that is unique to the remote LLDP-MED.
PSEPowerAvailable
Specifies the power available from the PSE connected remotely to the specific port.
PSEPowerSource
Specifies the type of PSE Power Source for the remote LLDP-MED.
  • unknown
  • primary
  • backup
PSEPowerPriority
Specifies the power priority associated with the PSE LLDP-MED, for more information, see RFC 3621.
  • unknown
  • critical
  • high
  • low
