![Note](images/note.png)
Originator ID cannot be deleted if MSDP is enabled.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
- Select MSDP.
- Select the Globals tab.
- In the RPAddress box, type the IP address to use as the originator ID.
- Select Apply.
Global field descriptions
Use the data in the following table to use the Globals tab.
Name |
Description |
Enabled |
Enables MSDP. If you clear this check box, you disable MSDP. The default setting is clear (disabled). |
CacheLifetime |
Configures the lifetime given to SA cache entries when created or refreshed. |
NumSACacheEntries |
Displays the total number of entries in the SA cache. |
RPAddress |
Specifies the IP address to use as the originator ID. If the address is not a system local address, the system rejects the configuration. |
RouteMapName |
Specifies the name of the optional route policy to create or modify. You do not need to create a route policy to use the redistribution filter. Note:
To delete the route map name, clear the field and click Apply. |
RedistributeFilterEnabled |
Filters the (S,G,RP) entries provided by PIM to MSDP. The default is clear (disabled). |
RedistruteFilterApply |
Applies the changes made to the redistribute filter. |
StatsClear |
Clears MSDP statistics. |
