If traffic is not moving properly, use the following procedure to determine the issue.
  1. Enter Privileged EXEC mode:
    enable
  2. Ensure that all switch nodes in the network operate with the most recent software release to support IP Multicast over Fabric Connect:
    show software
  3. Ensure that you create and enable SPBM infrastructure globally.
    1. Ensure that SPBM is enabled globally:
      show spbm
    2. Ensure that IS-IS is enabled globally:
      show isis
    3. Ensure an SPBM instance exists with at least one Backbone VLAN (B-VID). Also ensure multicast is enabled:
      show isis spbm
  4. Ensure that you enable the CFM configuration.
    1. Ensure a CFM maintenance-association exists:
      show cfm maintenance-association
    2. Ensure a CFM maintenance-domain exists:
      show cfm maintenance-domain
    3. Ensure a maintenance-endpoint exists in the MEP ID column and is enabled in the ADMIN column:
      show cfm maintenance-endpoint
  5. Ensure a Customer VLAN (C-VLAN) exists and ensure you add UNI ports to the C-VLAN.
    1. Display C-VLAN information:
      show vlan i-sid
    2. Display ports for the C-VLAN:
      show vlan members port {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
    3. Display NNI and UNI receivers:
      show isis spbm ip-multicast-route detail
  6. Ensure that you assign the same I-SID to the C-VLAN on all of the BEBs where you configure the C-VLAN:
    show vlan i-sid
  7. Ensure that you enable IP Multicast over Fabric Connect globally:
    show isis spbm
  8. Ensure the you enable IGMP Snooping on the C-VLAN on all of the Backbone Edge Bridges (BEBs). Ensure the protocol configured on the VLAN added is snoop-spb in the MODE column, which indicates IGMP is enabled on a VLAN with an associated I-SID (IP Multicast over Fabric Connect for a Layer 2 VSN):
    show ip igmp interface
  9. Ensure that you enable IGMP Snooping on access Layer 2 switches to prevent flooding of multicast traffic to non-receiver ports:
    show ip igmp snoop-trace
  10. Ensure that the IGMP version used by the multicast hosts and the Layer 2 switches outside the SPBM network is the same as the IGMP version configured on the C-VLAN:
