Use the following procedure to generate the private and public key pair. By default, VOSS generates a 2,048 RSA key when the system starts. You can use this procedure to generate a new key.
  • Configure an EJBCA CA server.
  • Configure a route from Fabric IPsec Gateway to the EJBCA CA server.
  1. Enter Fabric IPsec Gateway Configuration mode:
    enable
    virtual-service WORD<1-128> console
    Type CTRL+Y to exit the console.
  2. Generate the key:
    certificate generate key <type> <size> <key-label>
Switch:1>enable
Switch:1#virtual-service FIGW console
FIGW>certificate generate key rsa 2048 key_rsa
  fingerprint:    09ac0c64b9bf3ad04dc67f20942c674e
The following table defines parameters for the certificate generate key command.
Variable Value
key-label
Specifies the key name of the generated key pair.
size
Specifies the size of key-pair to be generated. The switch supports 2048.
type
Specifies the type of cryptography algorithm used to generate the key-pair. The switch uses only rsa as the cryptography algorithm type.
