Configure a forced message control pattern to enforce configured message control actions.
  1. In the navigation pane, expand Configuration > Edit > Chassis.
  2. Click the Force Msg Patterns tab.
  3. Click Insert.
  4. In the PatternId field, enter a pattern ID number.
  5. In the Pattern field, enter a message control pattern.
  6. Click Insert.
Force Msg Patterns Field Descriptions
Use the data in the following table to use the Force Msg Patterns tab.
Name
Description
PatternId
Specifies a pattern identification number in the range 1–32.
Pattern
Specifies a forced message control pattern of 4 characters. The software and the hardware log messages that use the first four bytes matching one of the patterns in the force-msg table undergo the configured message control action. You can specify up to 32 different patterns in the force-msg table, including a wildcard pattern (****). If you specify the wildcard pattern, all messages undergo message control.
