![Note](images/note.png)
This procedure does not apply to VSP 8600 Series and XA1400 Series.
You can disable EAPoL authentication for specific Fabric Attach (FA) client types.
By default, authentication is required before the connection is authorized.
The following table defines parameters for the auto-sense commands related to EAPoL authentication for Fabric Attach (FA).
Variable |
Value |
{authorized | auto} |
Configures the EAPoL authentication requirement for the specific client type. Choose from the following options:
By default, authentication is required before the connection is authorized. |
