Use the following procedure to display information about the configuration of RADIUS dynamic session changes.
  1. To enter User EXEC mode, log on to the switch.
  2. Display information about dynamic change configuration:
    show radius dynamic-server [client | statistics]
Switch:1#show radius dynamic-server
                        RADIUS Dynamic Authorization General Info
CLIENT                                   UDP        CLIENT     SECRET
ADDRESS                                  PORT       ENABLED    KEY
192.0.2.15                               1026       Disabled   ****************
192.0.2.16                               1027       Disabled   ****************
All 2 out of 2 Total Num of RADIUS Dynamic Authorization clients displayed
Display dynamic server statistics:
Switch:1#show radius dynamic-server statistics
                 RADIUS Dynamic Authorization Global Statistics
Disconnects From Invalid Client Addresses:     0
CoAs From Invalid Client Addresses:            0
The following table defines parameters for the show radius dynamic-server command.
Variable
Value
client WORD<0-46>
Display RADIUS Dynamic Authorization configuration values for the specified client.
statistics
Display statistics for RADIUS Dynamic Authorization clients.
