View the area advertisements and other information in the LSDB to ensure correct OSPF operations.
  1. Enter Privileged EXEC mode:
    enable
  2. View the OSPF link-state database:
    show ip ospf lsdb [adv_rtr {A.B.C.D}] [area {A.B.C.D}>] [lsa-type <1-11] [lsid {A.B.C.D}] [vrf WORD<1-16>] [vrfids WORD<0-512>] [detail]
Switch(config-ospf)#show ip ospf lsdb
                            OSPF LSDB - GlobalRouter
                Router Lsas in Area 0.0.0.0
LSTYPE     LINKSTATEID     ADV_ROUTER      AGE  SEQ_NBR    CSUM
Router     192.0.2.0       192.0.2.0       617  0x80000031 0xeafd
Router     198.51.100.0    198.51.100.0    1033 0x80000030 0xa5f2
                Network Lsas in Area 0.0.0.0
Network    100.1.1.2       192.0.2.0       617  0x8000002f 0xd038
                Summary Lsas in Area 0.0.0.0
                AsSummary Lsas in Area 0.0.0.0
                NSSA Lsas in Area 0.0.0.0
                                AsExternal Lsas
LSTYPE     LINKSTATEID     ADV_ROUTER      ETYPE  METRIC  ASE_FWD_ADDR    AGE  SEQ_NBR    CSUM
Variable definitions
The following table defines parameters for the show ip ospf lsdb command.
Variable
Value
adv_rtr {A.B.C.D}
Specifies the advertising router.
area {A.B.C.D}
Specifies the OSPF area.
detail
Provides detailed output.
lsa-type <1-11
Specifies the link-state advertisement type in the range of 1–11.
lsid {A.B.C.D}
Specifies the link-state ID.
vrf WORD<1-16>
Specifies a VRF by name.
vrfids WORD<0-512>
Specifies a range of VRF IDs.
