Configuring ARP ACEs
Use ACE Address Resolution Protocol (ARP) entries to ensure the filter looks for ARP requests or responses.
You cannot configure ARP attributes for IPv6 filters.
  • The ACL exists.
  • The ACE exists.
    enable
    configure terminal
  2. Configure an ACE for ARP packets:
    filter acl ace arp <acl-id> <ace-id> operation eq <arprequest|arpresponse>
  3. Ensure the configuration is correct:
    show filter acl arp <acl-id> <ace-id>
  4. Optionally, delete the individual attributes from the ARP portion of the ACE:
    no filter acl ace arp <acl-id> <ace-id> [operation]
  5. Optionally, delete all the attributes from the ARP portion of the ACE:
    default filter acl ace arp <acl-id> <ace-id>
Use the data in the following table to use the filter acl ace arp command.
Variable
Value
<acl-id>
Specifies the ACL ID. Use the CLI Help to see the available range for the switch.
<ace-id>
Specifies the ACE ID. Different hardware platforms support different ACE ID ranges. Use the CLI Help to see the available range for the switch.
Specifies the type of ARP operation to filter: arpRequest or arpResponse.
