Enable Ethernet statistics collection for RMON.
  1. In the navigation pane, expand the Configuration > Serviceability > RMON folders.
  2. Click Control.
  3. Click the Ethernet Statistics tab.
  4. Click Insert.
  5. Next to the Port box, click the ellipsis (...) button.
  6. Select a port.
  7. Click OK.
  8. In the Owner box, type the name of the owner entity.
  9. Click OK.
  10. Click Insert.
Ethernet Statistics Field Descriptions
Use the data in the following table to use the Ethernet Statistics tab.
Name
Description
Index
Uniquely identifies an entry in the Ethernet Statistics table. The default is 1.
Port
Identifies the source of the data that this etherStats entry is configured to analyze.
Owner
Specifies the entity that configured this entry and therefore uses the assigned resources.
