Use the following procedure to enable DHCP Snooping globally. If DHCP Snooping is globally disabled, the switch forwards DHCP reply packets to all required ports, both trusted or untrusted.
    enable
    configure terminal
  2. Enable DHCP Snooping globally:
    ip dhcp-snooping enable
  3. Disable DHCP Snooping globally:
    no ip dhcp-snooping enable
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip dhcp-snooping enable
The following table defines parameters for the ip dhcp-snooping command.
Variable
Value
enable
Enables or disables DHCP Snooping globally. By default, DHCP Snooping is disabled.
