Configure a redistribute entry to announce certain routes into the RIPng domain, including static routes, direct routes, Open Shortest Path First (OSPFv3), IS-IS, or Border Gateway Protocol (BGP+).
  • Enable RIPng globally.
    enable
    configure terminal
  2. Access router RIP configuration mode:
    router rip
  3. Enable the redistribution:
    ipv6 redistribute {direct|isis|static|ospf|bgp} enable
  4. Ensure the configuration is correct:
    show ipv6 rip redistribute
Enable the redistribution instance.
Switch:1#enable
Switch:1#configure terminal
Switch:1(config)#router rip
Switch:1(config-rip)#ipv6 redistribute bgp enable
Switch:1(config-rip)#ipv6 redistribute direct enable
Switch:1(config-rip)#ipv6 redistribute isis enable
Switch:1(config-rip)#ipv6 redistribute ospf enable
Switch:1(config-rip)#ipv6 redistribute static enable
Switch:1(config-rip)#show ipv6 rip redistribute
                            RIPng Redistribute List
        direct                         : enabled
        static                         : enabled
        ospf                           : enabled
        bgp                            : enabled
        isis                           : enabled
Variable definitions
Use the data in the following table to use the ipv6 redistribute command.
Variable
Value
<bgp|direct|isis|ospf|static>
Specifies the type of routes to redistribute (the protocol source). Valid options are bgp, isis, direct, ospf, or static.
