![Note](images/note.png)
This procedure does not apply to
VSP 8600
Series and
XA1400
Series.
Perform this procedure to configure an Auto-sense Data I-SID on a port.
In the Device Physical
View tab, select a port.
In the navigation pane, expand
Select General.
Select the Interface
tab.
For AutoSenseDataIsid, type the data I-SID value. The range is 0 to
15999999.
Select Apply.
