Perform this procedure to display the default configuration file on the Fabric IPsec Gateway Virtual Machine (VM).
enable
virtual-service WORD<1-128> console
Type CTRL+Y to exit the console.
show default-config-file
Switch:1> enable Switch:1# virtual-service figw console Connected to domain figw Escape character is ^Y <cr> FIGW> show default-config-file coupled.cfg
